Find out axes
Good afternoon.
I'm starting to program in Solid Edge and would like to make an inquiry.
Sheet metal environment. I have a flat piece whose sketch is drawn on the  axis X:Z. Does exist the posibility to know from the code, the pair of axes in which it has been drawn the sketch?
I want to know that information to create a plane with the front view.
Thank you very much.
