Flat Pattern Issue ST7
I've an issue with sheet metal. When the folded box is flat patterned it moves one of the flanges as per the photograph. Does anyone have any ideas what is causing this and how to rectify it?
Thanks Graham
Re: Flat Pattern Issue ST7
Wow, that's an odd one Graham......are you able to share the file?
Testing: Solid Edge 2019
Sorted with vendor. It was a closed corner that was creating the issue. opened the gap to 0.75mm and it prevented it. However, what is not good is that parts were cut to the DXF and are wrong Smiley Sad
