Flaten disjoint error
Hello everyone.
I hae an unsual error (to me) that I cannot quite figure out.
Here is the video link to it:
https://www.youtube.com/watch?v=_Jh1hjMemWg
I need to get this piece to be flatten so that I have the capability to run it through our laser cutting equiptment without any error.
Thank you for your input.
Luther
Re: Flaten disjoint error
Update.  attached is the psm file for it.  There is a cutout that has a small "V" that is floating in the air in the cutout between the two small holes.  I think that is where the error is.
