Flatten a curved part
Would like to ask for help on how to flatten the attached curved part.
Using ST9 version.
Thanks.
4 REPLIES 4
Re: Flatten a curved part
Hi @Mikel06
In my opinion you should first to save all two parts separately and the use the command Blank Body ( Tools ).
Arek
Hi @Mikel06
you can make an offset of the surface and then make a Blank Surface command as well,
regards,
Arek
Hi @arekkul,
Thanks for the answer, but is there a way to flatten the parts without separating them?
Thanks & regards,
Mikel
Hi @Mikel06
I think there is no possibility to do that.
regards,
Arek
