Flatten rolled U
Any idea how I can flatten this?
Solid Edge 2019 & AutoCAD 2019 user
Re: Flatten rolled U
Hi Joris,
You very simnply can solve that using a contour flange for the large arc, which becomes the base of the U-profile, followed by 2 contour flanges for the sides.
If You do this in sequential mode Solid Edge will bring You a proper result for the flat.
Wolfgang
Wolfgang
... by the way:
ST7 will flatten everything within part.
There is a new flat function!
Wolfgang
Wolfgang
Thanks!
Your first option works perfect. We use ST7, I tried other things, but no result.
Yes, @hawcad is right.
Here is a short video about solutions:
I hope, this will be useful...
BR,
Imics
