Fluid and Air Simulation
I would like to say thank HJoy for the help with the rotor compression. I was able to fix.
Question: What is all involved in doing a fluid and air simulation within Solid Edge?
Thank You
Greg
Re: Fluid and Air Simulation
Great to hear you sorted it out!
Unfortunately, you’ll need an add -on, FloEFD or similar. Even SE Premium won’t do this by itself.
