Re: Format File Name in Property Text
Honored Contributor
Honored Contributor
I have been wanting stuff like that since the start.
  • Place variables into the Document number slot like: Assembly file name + Part file name + Text string
  • The ability to place Document name formula into draft
  • The ability to have variable names a function of the assembly and part variables
In general, when I rename an assembly or part, I want that to affect everything, including variable names related to parts. Now if you ask am I talking about the file name or the Document number, My response is both or either.
Hello @uk_dave,
Thank you for the solution. That is awsome!
I have a query. I have SE 3d files with custom properties. I want to sort those files in windows folder similary as you shown for Project name or Document number with their custom properties. But I can't find a way how to show custom properties in windows folder.
Can you please suggest? It will help a lot!
Aslam
@aslam I do explain how to accomplish that already in this thread.  Look at the following post:
https://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Format-File-Name-in-Property-Text/m...
