Format issue with a Radii and Dual Dims
Any suggestions on how to correct the overlapping of the R and the 4.0 ±0.2 dimension in the attached picture?
I also can't remove the projection line for same dim, just visable on lower left corner of arc.
ST9 MP9
Gary Dinges | Mechanical Design Engineer II | Probes & New Product Development
Emerson Commercial & Residential Solutions | Therm-O-Disc, Inc.| 1320 South Main Street | Mansfield | OH | 44907 | USA
T +1 419 525 8554
gary.dinges@emerson.com
Re: Format issue with a Radii and Dual Dims
One thing you can do is right click on the dimension, go to Properties and then go to the Spacing tab and change the Symbol gap value.
That works !!
Thanks, Gary
@Gary_Dinges  Change the justification on your secondary units tab of the dimension properties to "Left" rather than "Center".
http://Grundey.blogspot.com
Overlap fixed.
Still would like to turn of Red Projection Arc, highlighted in picture attached.
Gary
