Formating property text values
In the callout shown I'd like to remove the trailing zero's on the 82.000°. When I go to format the values its all greyed out no matter what property text I choose it wont let me format them.  Also trailing zeros are turned off in my styles and using a simple callout to the hole is shown as 82°.  Why is the callout in the hole table different?
Re: Formating property text values
also just typing in %{%HS/@2} outputs %{.281/@2} in the callout box
WAG: Roundoff in the format values dialog?
Bruce Shand
ST10 MP7 - Insight - Win10 - K4200
as i stated in my first post, its greyed out and will not let me format anything
Oops. Sorry
Bruce Shand
Honored Contributor
Honored Contributor
I don't think you get to edit for format until there is data. try adding a table, then adjusting the format.
Thats exactly what I've been doing.  It may be an ST8 bug as I've noticed a few strange behaviors since updating.  I'll give it a shot on our other ST7 machine and see if its reproduceable.
Does this work for you?.....
Testing: Solid Edge 2019
I cant beleive I didn't see that this whole time.  I've been playing with roundoffs in the styles.  Turning off trailing zero's below round-off did the trick.  Thank you
Glad to help.  Robot Happy
