Fractals and functions
Does anyone know how to use solidedge to make figures using fractals, for example A cube, on which is a cube 4 times smaller, on which another cube 4 times smaller, n times?
7 REPLIES 7
Re: Fractals and functions
Yes, manually.  No automated way.
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
You could insert the cube as a "Copy of the part" and scale it to desired scale many times as you want!
Yasser
Thanks for your reply. I know that, But I want to insert it as a function. So that I replicates and scales itself automatically!
ok!
You would need to write a VB macro to do this through the API if you want to automate it.
Thats closer to something I am looking for. Can you please elaborate?
You would need to install Visual Studio and write a VB or C++ application using the documentation in the SDK Help to manipulate the Solid Edge API to automate the functions you desire.  You can find resources in the Solid Edge Developer Forum here:  http://community.plm.automation.siemens.com/t5/Solid-Edge-Developer-Forum/bd-p/SEDeveloperForum
