Frame Drawing Visible Issue
I have spotted a quite strange visible problem on the Drawing environment with the Frame.
Any Idea how to solve it ?
Frame issue.pngDrawing issue FrameFrame issue - correct.pngModel correct Frame
Thank you for help.
Arek
Betreff: Frame Drawing Visible Issue
Hi @arekkul
I think without an example part and asm it get difficult to find a reason.
Could be the graphics but also it might be necessary to activate all parts in the asm
From the pictures it IMHO is not possible to find out where You are currently and what You are doing.
Wolfgang
Hi @hawcad,
I have uploaded the files.
when you open the drawing then you will see the issue.
Thank you,
Arek
Hi All,
Okay - Small UPDATE - I created separate Configuration just for the Frame and everything is working fine - but only using Configuration.
If I want to create standard drawing from Assembly file I am getting Frame drawing Issues.
Don't get it frankly ...
Arek
Hi @arekkul
I suppose this issue is made by Yourself!
You have 3 sections in the 3D ASM and those 3 all are activated in Yourmain view.
Creating new views from that will keep thos sections on and so the result shows exactly what You are requesting.
Turn off those sections and modify the view accroding to Your wishes.
Could this be the reason?
Wolfgang
Hi @hawcad
Thank you for response,
no, the issue is somewhere else,
I have deleted all sections - basically a part from the assembly.
And tried to create again Principal View ....
Screenshot attached,
Cheers.
Arek
Hi @arekkul
what I do not fully understand is how You have created this view.
When I create a new sid view it is quite differently!
Wolfgang
Try processing intersections on the troublesome drawing views.  I tried it and it looks like what you want.
right click on drawing view->properties->Advanced tab->Part intersections, select Process Intersections radio button then update views.
If you cannot find a Solid Edge setting, confirm you have a file open of the type that will be affected.
Hi @bnemec
This is working, thank you,
regards,
Arek
Hi @hawcad
you have to hide some parts from the view.
regards,
Arek
