Frame Extrusions not lining up
I do work for a sign company.  I have added a frame extusion profile to my library using the DXF from SignComp's downloads.  I drew my sketch I want to make into a Frame.  When I apply the Frame member to it, I ABSOLUTELY cannot get the profile to come togetherand miter correctly.
I have tried changing the reference base boint, reorienting the profile file, etc...
Please help!!!
See attached files
Re: Frame Extrusions not lining up
And here is the extrusion profile
Hi @lifofadrafter
OK, but can YOu tell us, where the problem is?
I just tried to use Your profile for frame and I have got a good corner treatment with a miter
And alos what I have seen in Your ASM looks pretty good.
Hi @lifofadrafter
marking this psot as solution, will this mean, that it wórks fro You too?
I finally got it.  When I select the chain (the rectangle) and apply the profile, it does good on three sides, but I have to manually go in and rotate and mirror the profile on the last side.
Hi @lifofadrafter
have You checked all options in the frame options menu?
There is a setting for optimal position and orientaion of the frame section.
As I can remember
Id love to find that setting
Hi @lifofadrafter
try this :
