Frame Path display in Draft
When I place a view containing frame components I always get the path displaying.
How do I turn this off - either at placement time or after the view is placed ?
At the moment I have to go to every frame member and turn off the centreline in the view properties.
HP Z420 16GB RAM
Quadro K4000
ST10 MP12 on Windows 10 Pro 64.
Re: Frame Path display in Draft
In the Drawing View Wizard just untick the 'Show axis' option
You can set as default in solid edge options / annotations
About exisisting views you can select all the 'Axis" by perfoming a search in Drawing View Property
Thanks Fiorini.
HP Z420 16GB RAM
Quadro K4000
