Frame components Issue
Have an inquiry regarding to the frame modeling.
How to create the drawings from indywidual parts of this frame ?
I know how to do using whole frame but how to do with the box sections individually ?
thank you,
Arek
Production: SE ST10 MP8
Betreff: Frame components Issue
When You have create a drawing view from the frame assembly You can create another view from any sub element of the assembly, either a sub assembly or a single frame part.
This is true if You do it within one and the same draft file.
If the goal should be different draft files then either I put a assmebly view out of the drawing area to follow the above procedere or second method, You can export and save single frame components out of the frame assembly.
This video is currently being processed. Please try again in a few minutes.
(view in My Videos)
(view in My Videos)
Wolfgang
Re: Frame components Issue
Honored Contributor
Honored Contributor
The one thing that makes in non-initiative is the view orientation preview step. Even though you are trying to display a single part, the preview shows the entire assembly, sometimes hiding the single part you are really just about to display.
Once the view is placed, just the singel frame segment shows up.
what do You mean by "showing the entire assembly"
When I'm creating the part view I only will se the single part
Wolfgang
Honored Contributor
Honored Contributor
Yes, but when you place the few, you see the entire frame in the draft view until you locate the placement.
no I don't think that I see the entire assembly.
Does this happen in the video?
Wolfgang
