Frame design: End cap/plate
How should I handle frame cap/ending/plate for square tubes?
I remember that SolidWorks had (or have) an automated tool, that would add end cap to open square tubes with a click on a button.
Does SE have something like that? Using latest version.
5 REPLIES 5
Re: Frame design: End cap/plate
Honored Contributor
Honored Contributor
No
How do you normally handle it then? Make a part (e.g. 50x50 Cap) and use that? Or....?
I do wish SolidEdge did have an end cap feature, but it doesnt.  As strong as the frame design function is, they should get it!
Honored Contributor
Honored Contributor
I make an assembly driven sheet metal part and create the first sketch on the end of the frame member.
If you have one size end cap that is common. I make it on it's own and assemble it.
That's what I do too
Sent from my Verizon, Samsung Galaxy smartphone
