Frame design not updating automatically
Since we upgraded from ST6, it has noticed that there are a few (interniitant) problems with frame design. When a path is modified, the frame component would update automatically. In ST7, this does not seem to be happening. We make the change and then have to exit frames and do a "Update active level" to get it to update.
This has been logged with GTAC (IR 7398605) and the best they can come up with is to update video drivers and re-install SE. Has anyone else experienced problems of this sort where users have to foce an update before it is displayed?
