Frame display error in Draft
Hi Edge-heads,
I have encountered this for a second time now.....and seems [so far] to only be drafts of "frame" models.
First time was updating an ST9 assembly & then it's drawing.....but now, this one I have made fully in ST10, and getting the same odd display artifacts [no selectable geometry], across the views. I have all the views set to process intersections, as I have such a condition in my design. It appears this way on my colleagues machine also.
Anybody else seeing this? [just to be clear what the error is - the assembly model is pictured below also]
Re: Frame display error in Draft
OK, I found a repeatable issue with FRAME models.....seems my preference for increasing the draft "Shaded View Quality" to 300ppi is where the issue lays. Roll the view quality over 150ppi, and instantly the shading falls off the model.
Can somebody else please try to repeat this error?
@Alan, can we get an IR going for this??
Not seeing it here @SeanCresswell
ST10, brand new frame-only assembly, frame-only draft views, process all intersections, switching between 150 and 300 ppi settings.
The views are updating fine.
Our graphics differ certainly: mine is a basic Intel HD 4600
~Tushar
Thanks for looking @Tushar......it must be something local, as my VAR can reproduce it with my test data, but can also place his own views that have no issues. Robot Frustrated
