Frame in adjustable assembly
Hello everyone,
I have question about using frame in adjustable assembly.
I create an assembly with frame in it, then insert it to another assembly model and set it "adjustable", and then add relationship. But the frame doesn't changed according to the new relationship.
Does frame only changed automatically when the assembly is not adjustable?
thanks in advance.
Hunter
Re: Frame in adjustable assembly
Honored Contributor
Honored Contributor
You will need to make the sketch that drives the frame adjust.
thanks, I will try with it.
Hi
I have tried it, but either draw a sketch or use line in frame function don't work.
that can drives in its own assembly but not in a higher level assembly.
Hunter
