Free 2d will not install to F: drive
Not applicable
Can not install free2d to f; drive.
error dialog: Error 1327.Invalid Drive c:\
do not have c: drive.
can not have usb drive as c: (cyber security req)
tried mapped network drive as c: - no joy.
PLEASE HELP ASAP.
Re: Free 2d will not install to F: drive
Not applicable
The installation software is expecting a drive called 'C:' You are not
required to install the software on the 'C:' drive, it just needs to be
there.
To get around the issue where there is not a 'C:' drive, others have been
successful by connecting a flash drive to the computer. Ensure that the name
of the flash drive is 'C:'.
You will still need to specify path where the software is to be installed.
Do not install the software on the flash drive.
Rick B.
