Free2D Tips Tip#2
Did you know that you can use existing AutoCAD block libraries directly in Solid
Edge 2D Drafting. If you have existing AutoCAD block libraries, navigate in Edge
Bar to the file folder where the AutoCAD block libraries reside. Click on one of
the AutoCAD block libraries. You may see a short delay while Solid Edge 2D Drafting
opens the AutoCAD block library file to display the available blocks. Once you see
the blocks in the list, just drag and drop the needed block into the drawing window.
The block places as a Solid Edge block. Cool!
