Re: Freeform Designing... then into NURBS CAD format
Honored Contributor
Honored Contributor
I think everybody here contribues what they can when they can. Great community.
When it comes to Nurbs, they are tied to surface modeling, and need to be involved if reverse engineering/3D printing are to be capcities of SE. Once you get into reverse engineering (point clouds) you need it all (Point, Polygons, Nurbs, Primatives) and the ability to back and frorth from any of them to any other directly.
@Craig_H This will be "your session" at SEU2016... Smiley Wink
11:15 AM  -  12:00 PM (Oct. 27, 2016)
Reverse Engineering in Solid Edge
Come learn about Reverse Engineering, a new Solid Edge beta-stage add-in that provides tools to convert STL mesh data to a Solid Edge part model. See how to import an STL file, repair STL mesh, identify shapes, extract surfaces, create a construction body, and convert it to a design body that is ready for editing and use in Solid Edge.  At the end of the session, you will have an opportunity to help direct future development of these tools.
BR,
Imics
