Get rid of broken Links
I have an assembly which seems to somehow hold onto some old links.
Except for the Edit Links window and the revision manager broken links search I can not find any problems with the assembly but I do not know how to remove these two.
Re: Get rid of broken Links
You need t ogo to the Part with the link within the Assembly and use the "Break All" command.
Watch here: http://screencast.com/t/suB77FWmu7re
Bob
where can one find the "Break All" command?
we're using ST6
@bbeally, Watch Bob's video.
Bruce Shand
ST10 MP7 - Insight - Win10 - K4200
wish I could
but our corporate firewal blocks it
this is why I as asking
Try Tools Tab>Assistants Group>Inter-Part Manager to break links.
Not sure what the actual problem is though.
Do you get load errors when you open the file?
I think the big red X = Unloaded from memory in Edit Links.
LMGi
www.TLMGi.com
@bbeally In the video Bob opens the part with a link, drills down to the lowest level of the links item in the pathfinder, right clicks, and selects "break all".
Bruce Shand
