Good information to keep handy
I have had the same problem until I came across this video from a youtuber and I did not come across the information in the forum.
Cheers everyone!
https://www.youtube.com/watch?v=xhbC1UjPGNU
15 REPLIES 15
Betreff: Good information to keep handy
Hi @Lex-luthor
or turn on Auto-Jog then Solid Edge will position the dimensions by itself
where is auto-jog, please?
@hawcad
I've tried that, The sub panel that I was drafting for a customer is what is known as a shotgun pattern.  Many holes and little places in between them.  Such as the picture.  I have dims on both sides showing where each hole is for out QC shop.
@Trikefreak
If I am not mistaken it should be located in the dimension ribbon, under Automatic coordinate dimension.
See attached
ahhh, i've never had any luck with auto-coordinate
Me neither. And I still don't see any auto-jog. Is this a ST10 thing anyone?
@bshand
It might be.  I still use ST9, ST10 is still pretty new.
It's part of the Coordinate ribbon bar.
I do my own dim jogs anyway, so have not used this.....
EDIT: well, it seems not to be working for me.
@SeanCresswell, Yeah, I tried that button too and it did nothing.
