Graphic problem
I have a graphic problem in assembly.
When I have an open assembly, and passes over a part, the assembly dissapears.
I attach a video
(view in My Videos)
Any suggestions on what may be happening?
Best regards,
Xènia Turon
Betreff: Graphic problem
HI @xeniaturon
can You tell us something about Your hardware specifications?
Hi @hawcad,
I have a Dell Precison T7500 with Windows 7 Professional.
Intel(R) Xeon(R) X5650 - 12 GB and 64bits
NVIDIA Quadro 600
Hi @xeniaturon
OK, win7  and nVidia 600
Is it correct, that the 600 is a more or less smaller graphic ard, but should do its job anyway.
What settings have You set in Solid Edge options for the Graphics?
Hi @hawcad
Do you mean these options?
Best regards,
Xènia Turon
Hi @xeniaturon
try to change the Automatic Graphic Selection to manual  Graphics Card Driven (no Advanced)
Stop SE, Start again and see what happens.
Hi @xeniaturon
before changing check the Applications Graphic setting, wether the Quadro 600 is fully dedicated to Solid Edge.
You said this is a notebook, and normally they have an onboard graphic too.
Maybe here is a difference which one should be used.
Hi @xeniaturon
this was the reason?
Hi @hawcad
after changing to manual Graphics Card Driven it works better but when selecting parts it does not look quite right.
It would be an interim solution.
Thank you.
Best regards,
Xènia Turon
Hi @xeniaturon
so I would work on the graphics driver and graphics settings to improve the behaviour and performance
