HELP-custom preferences
Builder
Builder
I am trying to locate which text document(s) contains the "hole table" & "parts list" information that way I can share my settings with a co-worker.
Does anybody know which of the preference text documents hold the information for the two I am looking for?
-Nate-
Re: HELP-custom preferences
Nate,
These will normally  be found in C:\Program Files\Solid Edge ST6\Template\Reports\
Parts List settings are in DraftList.txt and the Hole Table settings are in DraftHole.txt.
It is probably a good idea to share the entire Template folder with your co-worker.
Note that by configuring the File Locations area under Solid Edge Options you can link to a common single location for these items.SE Options.JPG
Cheers
Mark
Builder
Builder
Thanks! They were in the reports folder. Also I didnt know you could share reports Smiley Very Happy
