HOLE TYPE=DOWELL IN HOLE TABLE CHART
Dear All
I am not able to put hole type as dowell in my hole table. while part modelling I used to make dowell holes. But after drafting and hole table it shows only "SIIMPLE" hole.How a mfgr. knows it is dowell with H7.
Re: HOLE TYPE=DOWELL IN HOLE TABLE CHART
Good question.  In the Hole database this information is in the "subtype" column and sadly there is no function in Hole Table or Property Text to access this property nor other properties like Fit or Size.  If I were you I would discuss a putting in a change request to Siemens with your reseller or directly with GTAC if you have that option.
Production: ST10 MP9, Testing: SE 2019
http://Grundey.blogspot.com
