HOW TO CHANGE PIPE MATERIAL
Dear sir ;
         Regarding the pipe design doubt i have to mantion the attached file kindly find the attached file.
          doude is
            how to change the material like ( steel & other material (plastics)
          which is having few material  if you have any video  link please sent  to me sir it's very helpfully for me
Thanks & Regards
 G.ANANDAN
Re: HOW TO CHANGE PIPE MATERIAL
Hi there,
If what you need doesn't appear in the list, then you'll need to browse for the material required, assuming of course, that it is on your system. If not you'll need to add it to the system library.
Solid Edge ST10 [MP8] Classic [x2 seats]
