HOW TO CREATE REVISION CLOUD IN SOLID EDGE DRAFT SIMILAR TO AUTOCAD
3 REPLIES 3
Re: HOW TO CREATE REVISION CLOUD IN SOLID EDGE DRAFT SIMILAR TO AUTOCAD
Solid Edge does not have an out of the box solution for this, something about it not being part of any documentation standard...
The following link has info about a commercial macro that will do this:  http://www.edgeaustralia.com.au/products-edge.htmI thought there was a free macro somewhere to do this but cannot find it readily...
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
OK THANK YOU
Another option available for creating a Revision cloud is from CADVertex:
http://www.cadvertex.com/revcloud.pdf
Tushar Suradkar
www.surfandcode.in
