HOW TO ENABLE EDIT DEFINATION FEATURE FOR SHEET METAL
HOW TO EDIT SHEET METAL PART CREATED IN SOLID EDGE ST6 AND EDIT DEFINATION FEATURE FOR SHEET METAL
Hi there,   Edit definition is only available in "ordered...
Hi there,
Edit definition is only available in "ordered" mode....I suspect you're in "synchronous" mode.
Testing: Solid Edge 2019
Re: Hi there,   Edit definition is only available in "ordered...
So how to go in suspect mode????
Sent from my iPhone
Choose Tools from the top menu. Then select Ordered from the Model.
