HVAC systems in Solid Edge
Any of you use Solid Edge to design HVAC systems? If so, could you please share some images or video captures of an HVAC system in SE? I have a prospect that asked me for examples and I can only find a few commercial flyers about it, but now "real world" examples.
Thank you,
Carlos
5 REPLIES 5
Re: HVAC systems in Solid Edge
@Cadflow,  Are you talking about an installation plan involving unit placement/hookup details and ducting/piping/wiring or are you talking equipment design?  Large commercial or residential?  If equipment, specifically what kind (Air handlers, A/C, Evaporators, cooling towers,...)?
http://Grundey.blogspot.com
Yes, an installation plan with piping, AC units,  etc... It can be commercial or residential, it's just an example. For equipment design we have a few examples available.
We use Solid Edge for HVAC design. Mainly for Air Handling Units (AHU) and other HVAC system components also.
Here are same pictures.szukito PG-kerettel-1.jpgSpecial airduct partAHU-1 without doors.jpgAHU without doorsAHU-1.jpgAHUAHU-1 System Meat factory II.jpgComplete HVAC systemMeat factory II.jpgComplete HVAC system in a building
Thank you! That was what I was looking for!
@rosnerf great job! I proud of you & yours. You do great things with Solid Edge in Hungary! Congrats!
Imics
