Harness Bundle Question???
Is it possible to join a wire in the middle of a Bundle without having the wire go through the entire path? Just like a brach of a tree? Im sure there is but I cant figure it out.
Re: Harness Bundle Question???
Are you talking about a splice?
No. It would be one main bundle with other bundles coming out of it. I have a main harness coming from the engine and it branches out to the fuse block and anouther goes to the dashbord and anouther brach to the exhaust.  When I try to add a wire to the bundle it has to go through every path point that the orginal goes through. I can just add a wire to the middle of the bundel if that makes sence.?
A picture's worth a 1,000 words.
I hope this helps
My orginal question is: Can I add wires to a bundle with out going through the entire bundle path?
First.jpgsecond.jpgWiring-harness.jpgOne main harenss "trunk" or bundle with many branches or smaller bundles coming out of it
Yikes! Look like harness I'm attempting to work on for some customer training.
