Hatching Problems with Sectioned ISO assembly views created from PMI Section
Hi gang,
Has anyone else had problems with the hatching overflowing in parts that are not sectioned? I have my 'create all face intersection' turned on in the view properties yet I still get alot of parts in my isometric section views having hatch overflowing into them. The view below is created from a PMI section. This problem happens to me quite often in my assembly drawings and I have to end up turning off the hatch for specific parts and insert it in manually. This is a major hassle and any help in this matter is much appreciated.
Re: Hatching Problems with 2D assembly views created from PMI Section
Bump
