Have we lost filling out property info in save dialog box with st10?
Installed ST10 and have noticed I no longer have the options to fill out properties when saving. Is this something I have turned off or has it been droped?
Cheers Shayne
Re: Have we lost filling out property info in save dialog box with st10?
Hi @SHAYNE,
Yes, it appears so......not sure the logic behind that. It was handy having access to these fields at that point.
Hope there is a way to bring that functionality back to the UI.
Settings -> Options -> Manage and then toggle on "Use Solid Edge data management" will get you the three property fields back in the Save dialog.
Thanks for that Uk Dave. I was doing that earlier with no success, with your info at hand. I found there was one more step on top that, I had to also uncheck "Automatically name files via doucument number and rev".
@uk_dave,
Not that I use BiDM, but the solution for this topic is PERFECT!  Robot Very Happy
I seem to have lost thes Boxes again and cant turn them on again with the solution we can to above. Any one else having this issue?
Cheers Shayne
@SHAYNE, nope, still have them available here.
