Having C-size drawing printed
Not applicable
I would like to have a C-size drawing sheet printed. Does anyone know if there are companies that provide that type of service? And what format would I save the drawing or image? I checked the Kinkos website but I did not see a format that matched any of the SolidEdge formats.
Rich
Re: Having C-size drawing printed
Not applicable
Try a PDF printer driver like doPDF and set the page size for C size dimensions. Then places like Kinkos should be able to print it.
Not applicable
Thanks for the tip.
Does anyone know if a .xps file would work? Or a .jpg file that was saved from a C size drawing?
Rich
Not applicable
If the jpeg was full size they might be able to print it but I think the PDF is a safer option when you are dealing with relatively unskilled printers.
