Having trouble extruding a sketch up to a surface
I am having a problem extruding a sketch to a surface made bya closed boundary. The error says "the tool doesn't intersect with the to extent". Does anyone have any idea how to fix that? Thanks.
Dag
3 REPLIES 3
Re: Having trouble extruding a sketch up to a surface
Make your surface bigger so the extent doesn't spill off the edge
LMGi
www.TLMGi.com
Great thanks! I just did that and it worked. I appreciate it!
Dag
Honored Contributor
Honored Contributor
If I read into this correctly. Designing a flange to mate with a surface requires a plane that can be re-size and can't be used to match to an existing sheet metal surface.
Is this the case?
