Helical Protrusion ST6
How do you close the ends of the attached spring while in the Helical Prortrusion command?
Betreff: Helical Protrusion ST6
Hi @MJL
what is Your goal?
What should be "closed"?
Do You have a picture or description of what You are going to achieve?
Wolfgang
Re: Helical Protrusion ST6
Here's how I would do it:
Close:
Ground:
~Tushar
OK, is it, that You want to decrease the pitch of the spring at the ends, to have a couple of windings close together?
This is only possible in ST6 using multiple seperate helical protrusions with different pitch
Only with ST8 came a new curve type into Solid Edge giving You the chance to define such a spring curve in one single feature.
Wolfgang
My intent is to close the ends of the spring (see Closed diagram).
Thank-you!
Hi @MJL
ST8 if possible would be the best solution for that
Wolfgang
We are prepping for ST9 but have yet for it to be loaded.
Thanks for looking into this.
Appreciate it.
