Helical protrusion
I am a beginner in Solid Edge v20 and i can't seem to make a spring around a cylinder using the helical protrusion command. It should be easy but can anyone help ?
Re: Helical protrusion
the help file should be pretty straight forward.  if you want to create a screen capture video of your approach maybe we can help you out by noting a workflow issue.
as a beginner, Why are yo on V20?  you are 7 releases behind and learning old methods...
do yourself a big favor and get on ST6 or ST7  befoer investing a lot of time on your learning curve...
It's free so no reason not to.
   https://www.plm.automation.siemens.com/trialcenter/productinfo?welcome=1
