Help installing Solid Edge
N/A
Hi, I own a pc with Windows 7 home premium, 64 bit and I've been trying to install the software for days, following the instructions I got on my email but I can't seem to make it work.
I get a sign telling me that the system couldn't install the software and to try again later.
What can I do?
Can anyone help me?
Re: Help installing Solid Edge
Esteemed Contributor
Hi there,
You might try doing a RMB click on the "SolidEdgeV104ENGLISH_32Bit.exe" file, and choose "Run as administrator"....this assumes you are logged in as the administrator, and/or have administrator rights, on your PC.
The you should be able to run the software, and save the license file to the correct location.
Solid Edge ST10 [MP6] Classic [x2 seats]
