Help to show dimention
Help me to show Solid Edge dimentions.
I'm using Solid Edge with normal dimention show, suddenly dimention is not show.
(view in My Videos)
Re: Help to show dimention
@TuBui
Have you read through the various suggestion in this recent thread.
Perhaps one of those suggestions help fix the problem you are facing:
http://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/Dimensions-Error/td-p/349799
~Tushar
