Help to stitched surface part to Solid part
I have a step part, when i open (.step) part on Solid Edge, but it's a surface part.
I used stitched feature but this feature hide
Please show me how to change surface part to solid part (part in attachment)
Thanks!
5 REPLIES 5
Re: Help to stitched surface part to Solid part
there is a little gap between two faces. Here is how i fixed it.
Greetings from Germany
Christian Kunkel
https://c-k-m.info
Hi Christian,
I got it, Thank for show me
@ckunkel72,
At 0:26 in the video what did you do that made that surface go into segments? I don't see any action performed except for picking the surface.
Bruce Shand
@bshand,
i selected the surface and then hit DEL-Key to delete the surface. Syncronous is your friend at this step ;-)
Christian Kunkel
https://c-k-m.info
OK. Couldn't see you hit the delete key Smiley Happy
Bruce Shand
