Help with newly install and SELicense.dat
Not applicable
Free Apps on the Net are so simple to use: downloaded, installed and use it. Plain
and simple really. However, SE, all this license and whatnot, why cant you guy just
package it all together for newbies. I have installed many of free apps and they
all are ez, except this SE.
I did all that the steps that came with the email and still nada. Could someone
help me to run this on my Windows XP. Here was on the email about changing SELicense.txt
to SELicense.dat and put it inside the C:\Program Files\Solid Edge 2D Drafting V19\Program
should be simple but yet this it's pretty hard to get it right. Here are the error
that I got and maybe someone could help me fix this.
A connection to the license file server could not be established. Contact your system
administrator to resolve the connection to the server.
Cannot find license file.
The license files )or license server system network addresses) attempted are listed
below. Use LM_LICENSE_FILE to use a different license file, or contact your software
provider for a license file.
Feature: server_id
Filename:
License path:
FLEXnet licensing error:-1,359. System Error:2 "No such file or directory" For further
information, refer to the FLEXnet Licensing End User Guide, available at "www.macrovision.com"
tyia
Re: Help with newly install and SELicense.dat
Not applicable
Lance,
Do you have another CAD package such as AutoCAD loaded on the same machine?
Rick B.
Not applicable
"Ricky Black" wrote:
>Lance,
>Rick B.
Not applicable
William,
Is there a question here?
Rick B.
