Hidden Text
Not applicable
How do you get to the hidden text to relocate it? I'm referring to the author, title,
part number and revision level text which are automatically placed for you. I want
to relocate them but hate having to modify the background sheet every time I open
a new size sheet. I tried finding it in the normal.dft template but was unsuccessfull.
Ed
8 REPLIES 8
Re: Hidden Text
Not applicable
Ed,
It sounds like you know where the objects are, which is on the background
sheet. You just want to make the change one time so that it is available for
all draft files you create.
The templates are in "C:\Program Files\Solid Edge 2D Drafting V20\Template"
You should see the "normal.dft" file there. There is also a subdirectory
called "more". This is a place where you can add your own customized
templates.
Create a new draft file and make the modifications you want for your
template.
You now have a couple of options:
1. You can now save the file to the template directory above and name the
file "normal.dft". This will overwrite the default template file.
2. You can also, and this is what I suggest, save the file to the "more" sub
directory under the template directory. Give the file a valid name you would
use for your template. You can create as many customized templates this way
as you need. When you create a new draft file, click on the "more"tab in the
File New dialog. You will see your custom templates. The draft file will be
based on your template selected.
Rick B.
Re: Hidden Text
Not applicable
Rick,
I must not have explained what I meant very well. I'm probably not using the poper
terminology so please bear with me. I have already done what you are suggesting
below. My only problem is that I don't know how to relocate the text that is placed
automatically such as:
1. the author is placed next to the "DRAWN." box
2. the title is placed in the "TITLE" box
3. the drawing number is placed in the "DWG NO" box
4. the revision level is placed in the "REV" box
I know how to populate these in the "File Properties" diaglog. It's when the fields
are added to the drawing automatically that I can't seem to control where they are
placed. I want to know how to control the placement of the above mentioned fields
so the are located in the place of my chosing on the drawing. Does this make any
sense to you?
Ed
"Ricky Black" wrote:
>Ed,
>templates.
>template.
>Regards,
>Rick B.
Re: Hidden Text
Not applicable
Ed,
Maybe I'm not understanding the issue but you should be able to go to the
background sheet and just move the text to whereever you want. Once you do
so make sure you file over the template file as Ricky described.
Is there some reason you can't move this text?
David
"Ed Kadlec" wrote in message
news:47bf133a$1@bbsnotes.ugs.com...
> Rick,
> the poper
> suggesting
> is placed
> the fields
> they are
> fields
> make any
> sense to you?
> Thanks,
> Ed
>>Ed,
>>for
>>V20\Template"
>>templates.
>>template.
>>sub
>>would
>>way
>>the
>>be
>>Regards,
>>Rick B.
Re: Hidden Text
Not applicable
David,
Thanks for the attempt at helping but I guess I'm still not explaining the problem
I am having in positioning the specific text I am having problems with. This will
be my last attempt and then I will give up.
I know how to locate the text that shows up on the background sheet and I have done
that. The problem I am having is with the text that does not show up on the background
sheet but seems to be placed automatically. They are, as stated earlier:
The author, title, drawing number and revision level. They do not show up on the
background sheet until those fields are populated in the "File Properties" dialog.
Then I can go to the background sheet and relocate them where I want them. There
has to be something that tells the program where to locate the above fields on the
drawing and that is what I'm trying to get help on. I don't want to have to go to
the background sheet every time I start a new drawing and move that text where I
want it. Any clearer? I could send a before and after PDF file showing what I am
talking about if that would help.
Ed
"David Rieschick" wrote:
>Ed,
>David
>> Rick,
>> the poper
>> suggesting
>> is placed
>> the fields
>> they are
>> fields
>> make any
>> sense to you?
>> Thanks,
>> Ed
>>>Ed,
>>>for
>>>V20\Template"
>>>templates.
>>>template.
>>>sub
>>>would
>>>way
>>>the
>>>be
>>>Regards,
>>>Rick B.
Re: Hidden Text
Not applicable
Ed,
I think I understand your problem. The property text is placed as a
Callout which will have three justifications. It will stay were you placed
it relative to the justification point, so it is imperative that the correct
justification is chosen for the area that the text will be placed in. As
you found out, you cannot see the Callout till the property populates it, so
you must open your template, assign text to the property fields that
populate the callouts, position them where you want them (make sure the
justification is set such that they will stay where you want them), remove
the text from the properties, and save the template.
PellaKen
http://grundey.blogspot.com
news:47c09fd6$1@bbsnotes.ugs.com...
> David,
> problem
> This will
> have done
> the background
> on the
> dialog.
> There
> fields on the
> to go to
> where I
> what I am
> Thanks,
> Ed
>>Ed,
>>do
>>David
>>> Rick,
>>> the poper
>>> suggesting
>>> that
>>> is placed
>>> the fields
>>> where
>>> they are
>>> mentioned
>>> fields
>>> make any
>>> sense to you?
>>> Thanks,
>>> Ed
>>>>Ed,
>>>>background
>>>>for
>>>>V20\Template"
>>>>templates.
>>>>template.
>>>>the
>>>>sub
>>>>would
>>>>way
>>>>the
>>>>be
>>>>Regards,
>>>>Rick B.
Re: Hidden Text
Not applicable
Ken,
Thank you very much! That did it. That is exactly what I was looking for.
Ed
"Ken Grundey" wrote:
>Ed,
>so
>PellaKen
Re: Hidden Text
Not applicable
Ed,
I can see now why we're having a hard time understanding each other. I have
updated my templates so that each of the fields you are referring to have a
default value already entered into File Properties. For example, my
template already has "A" as the revision level. If I want to reposition any
of these callouts I just open my template, move them to the new location and
resave the template.
Apparently you have never entered default values into your template. Thus,
you have nothing to reposition. Open your template files, popuate these
filed with a default value, reposition as necessary and resave.
David
> David,
> problem
> This will
> have done
> the background
> on the
> dialog.
> There
> fields on the
> to go to
> where I
> what I am
> Thanks,
> Ed
>>Ed,
>>do
>>David
>>> Rick,
>>> the poper
>>> suggesting
>>> that
>>> is placed
>>> the fields
>>> where
>>> they are
>>> mentioned
>>> fields
>>> make any
>>> sense to you?
>>> Thanks,
>>> Ed
>>>>Ed,
>>>>background
>>>>for
>>>>V20\Template"
>>>>templates.
>>>>template.
>>>>the
>>>>sub
>>>>would
>>>>way
>>>>the
>>>>be
>>>>Regards,
>>>>Rick B.
Re: Hidden Text
Not applicable
David,
That explains the misunderstanding for sure. It now makes sense to me. Ken figured
out what I was referring to and straigtened me out. Thanks for your help.
Ed
>Ed,
>a
>David
