Hidden lines visible in detail view....
It has to be something simple that I'm missing but is there a way to leave the parent view with no hidden lines but then show hidden lines on the detail view?
I want hidden lines visible on Detail A
Re: Hidden lines visible in detail view....
Right-click on the detail view and select "Convert to Independent Detail View".
You will now be able to control edge display separately from parent view by right-clicking on detail view-->Properties-->Display tab.
Michel
Great!  I knew it had to be something easy like that.  Thanks!
Not sure which version you are using, but there is a bug in ST7 when changing a detail view to an independant detail view if the view has then been rotated. The change fails to take account of the rotation and you will get an empty or incorrect view.
HP Z420 16GB RAM
Quadro K4000
ST10 MP12 on Windows 10 Pro 64.
