Hide Protusion in Draft
Can we hide some protusion/extrusion/feature of a part  in drawing(draft)?
Just like we can hide some part of assembly in an assembly drawing.
Solid Edge ST9 User
Window 10
3 REPLIES 3
Betreff: Hide Protusion in Draft
Hi @Muhammad_Ayub
if You define a "Simplify Model" in Your part, You can show this in draft and/or use it in an assembly
Look for "Simplify Model" under the "Tools" tab when within a part or psm
Here is a picture from the tutorial (page 244)
Wolfgang
@hawcad thank you for the suggestion, but the simplify mode has minimum feature tu be used. I'm more than happy if you have other suggestion to try.
Hi @Muhammad_Ayub
what do You mean with "minimum feature to be used"?
You can show the simply model or the finished model.
What else might be wanted?
Wolfgang
