Hide/show groups in draft
I've been able to group objects in draft, then right click and hide.  Where is the "show" group command?
Also, what is "make non-locatable"?
Re: Hide/show groups in draft
Hi @Planker81
Show is here:
Also, Make non-locatable means you will not be able to select the group with the mouse.
~Tushar
Builder
Builder
*I do not know the answer to your first question, but this may help you...
NON-LOCATABLE:
-Siemens Documentation-
  1. On the drawing, click the group or groups you want to make non-locatable.
  2. Right-click to display the shortcut menu, and then choose Make Non-Locatable.
Tip
  • You can also select the group you want on the Group tab in Library.
  • When you make a group or groups of elements non-locatable, the symbol next to the group on the Group tab changes to indicate the group is no longer locatable. You cannot select the group in the graphics window later.
  • To make the group or groups locatable later, click the group name on the Group tab, and then choose Make Locatable from the shortcut menu.
