Re: Hiding "Error: No refernce" from Property Text Output
Yes. These will set for all users that point to the admin file.  I have chosen to keep it locked and show a "-" for the error.
Please use SEAdmin.exe to edit your Options.xml file.  Yes, it is an xml file that you can edit by hand but if you make a mistake...
Although some may knock SEAdmin, the one thing it does well is stop you from making manual errors in your Options.xml file.
