Hinge Rotation.
Can anyone show me how to get this hinge to rotate? Set limits of travel?
3 REPLIES 3
Re: Hinge Rotation.
You can do this by creating an angular assembly relationship between the two inside faces of the plates. You would set the Angle Type to 'Range' to set your angle limits. When defining the relationship, select the top flat face of the hinge for the measurement plane.
Hope this helps,
Greg
Re: Hinge Rotation.
Got it working thanks Greg! Smiley Wink
Re: Hinge Rotation.
No problem, glad to help!
