Hold Groups to Next Assembly
Good Afternoon,
Is it possible to hold Groups on a locked position into the next assembly. I have 10 Groups already set to the main doc. I want to add that part to assembly. Every time I add that part... Always opens all of the commands have to regroup again. Any Thoughts.
Thanks Everyone
Greg
the "group" only lives in the assembly it is created in....
Can you create a sub assy out of these componants if you need to reuse them so many times?
IF so,  the transfer command in the modify group is the tool you are looking for:
Select all the parts, transfer, create new subassy
then you can add the sub assy to the other assys needed?
HTH
Matt Johnson
Application Engineer
Ally PLM Solutions
matt.johnson@allyplm.com
http://allyplm.com/
