Hole Name in Pathfinder with Hole Size
Siemens Creator
Can I get the hole name in the Pathfinder to be displayed in the following format:
"HoleName_HoleSize"
Does anybody know of automating/an available API that can be shared? Thanks in advance.
5 REPLIES 5
Re: Hole Name in Pathfinder with Hole Size
Last link on this page Anshuman.
Does some reseller want this ?
Siemens Creator
Hi Tushar,
Thanks for the quick response. Appreciate it!
This is for an existing customer.
Can you please share a video/"steps to use" this tool? Why I ask, is because I see that this has to be re-run, if a hole edit is made. Please see attached video.
(view in My Videos)
Thanks.
Hi Anshuman:
Your video shows the correct usage of the macro. It was written to be used in this way.
The macro does not monitor hole size changes nor update the hole name in PathFinder automatically.
Also if you could have the customer directly participate on this forum - that would be great. Not for just this post, but encourage them to join and use the forum. Thanks.
Tushar
Siemens Creator
Yep. Have shown them the Community site, and they will be active soon!
Is there a similar utility for Sheet Metal too?
I will give it a try.
This will be a paid app.
Let me know if the customer agrees.
