Hole callout with qty in callout.
Is there any posibility to get qty of holes while placing hole callout?
if i placed M6 Thru 4 no. holes in hole feature of 3d model file then while drafting i placed hole callout, hole size & qty should be displayed automatically.
6 REPLIES 6
Re: Hole callout with qty in callout.
IS THIS WORK IN ST8?
But I am using ST8.
Somnath
If you add %QC in your suffix or subfix of the hole callout SE will count them.  There are also several other codes that will count holes.  An easier way is the use the "symbols and values" button.  See below:Hole Count.JPG
Kyle Joiner
IPA LLC
ST10 MP1
Thank You.
but i am using ST8 version.
The %QC code should still work in ST8 if the special characters button is not available.
Kyle
Kyle Joiner
IPA LLC
ST10 MP1
